I'm eliminating the headlight switch from the handlebars and wanted to know how to connect or re-wire that part to keep the headlights on all the time without the use of a switch?
cut the wires, and splice as follows: yellow with red stripe is power; connect to yellow for high beam, blue for tail light, and i think grey is low beam. i like to use a heatshrink butt connector, or solder and heat shrink, if you're real good at soldering. wrap them up with electrical tape once you fold them up behind the plastics and zip tie them to the frame loop
Each headlight has a yellow and a green wire coming from it, so am I to understand that the green wire is high beam and the yellow is low beam? If that is so, then it sounds like connecting the green wires to the yellow/red wire should solve my issue. Can anyone else confirm this?
yellow is high beam and green is low
Thanks for your help...it's kinda funny because I built the motor on this bike myself and have torn down my cobra motor and built it up several times, but when it comes to electrical I guess I'm retarted...LOL :banghead:
