willbanshee Posted December 19, 2008 Report Posted December 19, 2008 I put a set of used 34pjs on my shee. my bike is bored .80 over, cool head 22cc, trinity reeds,shear insiders. I ran the bike last weekend with 158 mains and 45 pilots it seemed to run good i checked my plugs and they looked good at 1/8 throttle, half throttle, and wide open. when i installed them i had it idling off the cable but once i ran it i came home and got it idling off the carbs. For some reason now when you open the throttle from idle it likes to bog, so i put 50 pilots, still same thing, so i tryed 55 pilots and it still bogs. Any help would be greatly appropriated because im very confused. Quote
bansee fever Posted December 20, 2008 Report Posted December 20, 2008 I put a set of used 34pjs on my shee. my bike is bored .80 over, cool head 22cc, trinity reeds,shear insiders. I ran the bike last weekend with 158 mains and 45 pilots it seemed to run good i checked my plugs and they looked good at 1/8 throttle, half throttle, and wide open. when i installed them i had it idling off the cable but once i ran it i came home and got it idling off the carbs. For some reason now when you open the throttle from idle it likes to bog, so i put 50 pilots, still same thing, so i tryed 55 pilots and it still bogs. Any help would be greatly appropriated because im very confused. just for the hell of it go back to your 45 main and then play with the needle a little ! are they in sinc? run the idle scew deal down all the way and see if it still does it? seems like I ran a 50 155 in my set up at sea level Quote
willbanshee Posted December 20, 2008 Author Report Posted December 20, 2008 just for the hell of it go back to your 45 main and then play with the needle a little ! are they in sinc? run the idle scew deal down all the way and see if it still does it? seems like I ran a 50 155 in my set up at sea level Yesterday when i did have the 45 still in the bike i tried dropping the needle down so to lean it out and still didn't help. Tomarrow i will try to turn the idle on the carbs down and try running from the cable and see what it does with the 55 pilots in it but i know thats not right so i tryed the rite way with the choke knobs but i cant figure it out Quote
