Yes the swingarm will bolt up ok.
The 87 had different mount locations for the chain sliders, so the 87 had different sized chain rollers. 89 has the odd ball hub bolt patterns and the different sized front brake calipers compared to the a-arm bikes. If you keep the same spindles and just add upper a-arms it will all work ok.
thanks a lot, so the only thing i am going to need to buy then is the frame and the upper a-arms and i will be set right
