serius4play Posted December 11, 2008 Report Posted December 11, 2008 hey, iv been lookin for a way to get cascade silincers on pc pipes, well i finally called cascade and they said that they will give you just the silincer pipe and then you use your old stingers to fit on there silincers and they nock off a hundred bucks! so i bet if you just order the silincers and use the old style stingers that you have with lets say your toomies or shears, CPI's you can get them for a 100 bucks cheaper. just thought id let ya know. Quote
Snopczynski Posted December 11, 2008 Report Posted December 11, 2008 hey, iv been lookin for a way to get cascade silincers on pc pipes, well i finally called cascade and they said that they will give you just the silincer pipe and then you use your old stingers to fit on there silincers and they nock off a hundred bucks! so i bet if you just order the silincers and use the old style stingers that you have with lets say your toomies or shears, CPI's you can get them for a 100 bucks cheaper. just thought id let ya know. I order the silencer cans and 2 sections of tube and the silencer flanges from Cascade. Then I bend the stinger tubes and weld them myself on the pro circuits. If you used the existing silencer tubes, you would have to bank on the fact that where they needed to be cut and welded, that the bend was right to go into the csfx silencer properly. Quote
