aust_banshee Posted December 11, 2008 Report Posted December 11, 2008 Whats wrong with the standard banshee exhaust? Is it because they have bafflers in them? If so, is it possible to take them out and what would the likely outcome be? Quote
BansheeRider87 Posted December 11, 2008 Report Posted December 11, 2008 Whats wrong with the standard banshee exhaust? Is it because they have bafflers in them? If so, is it possible to take them out and what would the likely outcome be? All you can do is take out the ends where the 3 screws are. And you don't gain any power by doing that. Only way is to buy after market pipes. There a lot more striaght through flow where stocks hold back a lot Quote
aust_banshee Posted December 11, 2008 Author Report Posted December 11, 2008 does it make you lose power? Does it sound OK? Quote
BansheeRider87 Posted December 11, 2008 Report Posted December 11, 2008 No doesnt do much of anything other than make a little bit more noise. Try it its take literally 30 a pipe. Sounds better than stock Quote
Snopczynski Posted December 11, 2008 Report Posted December 11, 2008 The stock pipes have an extremely narrow power window and are restrictive. Quote
