I have a new set of reeds and I want to swap mine out.
What is the fastest way to get to them?
Do I remove the airbox then carbs to get to them?
Or is there a cheat so I can avoid pulling everything apart?
I know this is pretty low on the pole but just let me know
You shouldn't have to remove the air box, just pull the carbs off and remove the boots and reeds and install the new ones.
thanks, I'll do that. I just don't want to make it a bigger job than it has to be.
It will be much easier to take the air box off...to be honest...rather than trying to squeeze in there, IMO.
I used a skim coat of RTV on the gaskets as well.
Good time to look down the backs of the carbs and make sure they're sync'd as well...
