mustfast65 Posted December 7, 2008 Report Posted December 7, 2008 Hi, newbie here. I have a STOCK 05 Shee which has crapped up carbs. It didn't run when I got it, but after $4 dollars worth of plugs it fired up and ran pretty good. I then tore the bike completely apart and cleaned it and restored the suspension and frame. Put the engine back in half way through rebuild(not rolling yet) and it fired right back up and ran good. Finally get it rolling again, start it up and let it warm up a bit and went to go ride it and it died. I could get it to restart, but not easily, and it would still die out. Checked plugs and noticed they were lean. I ELIMINATED THE TORS PER RECOMENDATIONS ON THIS SITE and still no solution. Getting good spark, and the TORS components check out good, but I still have them eliminated, contemplating doing a complete TORS elimination. So I found it to be a lack of fuel as I sprayed pre-mix through a squirt bottle through the carbs and it would run. Pulled the carns off and tore them down and noticed how crapped up they were. I was wondering if someone had a rebuild kit. It is STOCK and I am keeping it that way. The jets and needle and all other hard parts are ok, but I really want new gaskets and o-rings to put them back together. Does any company out there have rebuild kits or do I have to order the gaskets piece by piece. Thanks Quote
Paddleboy Posted December 7, 2008 Report Posted December 7, 2008 you can order them at any yamaha dealer or i'm sure there on some websites Quote
FASTOYS Posted December 7, 2008 Report Posted December 7, 2008 You guys should really look around at the sponsors sites at the top of the page.... http://www.farmandsandtoys.com/partdetail.asp?partid=188 Quote
