dirtfreak Posted December 12, 2008 Report Share Posted December 12, 2008 sounds like with the amount of play you have in your axle bearings they have been that way for a while.if the bearings have tried to seize in the axle carrier the new bearings may prematurely wear due to the old bearings spinning in the carrier.make sure the new bearings fit the carrier properly. Quote Link to comment Share on other sites More sharing options...
BUILDER Posted December 12, 2008 Report Share Posted December 12, 2008 (edited) sounds like with the amount of play you have in your axle bearings they have been that way for a while.if the bearings have tried to seize in the axle carrier the new bearings may prematurely wear due to the old bearings spinning in the carrier.make sure the new bearings fit the carrier properly. Good point firebanshee. I always foregt to mention that. We have done that to all of our bikes it does make the bearings last a lot longer. Edited December 12, 2008 by motor builder Quote Link to comment Share on other sites More sharing options...
