POORBOY350 Posted December 4, 2008 Report Posted December 4, 2008 (edited) ever since i adjusted my clutch like 3 weeks ago, i havent been able to figure out what this noise is. i thought it was the clutch being too tight or smtn, but im pretty sure its not. i took the cover back off and turned the clutch basket or just turned the motor over slowely and it just made this bad ass screetching noise. like metal to metal. its so bad you can feel it wen you barely turn it over. im pretty sure the noise is coming from the front bottom of the motor(which is right where the crank is :sad: . but i've never had to rebuild a shee before so im not that formiliar with the bottom end on them. it wasnt doin this before i adjusted the clutch. what could this noise be? how do i check for what it is? do i have to tear it down and get into bottom end? what could have caused this noise? cause i didnt see where i did anything major. its just a 'dry screetching' noise from front not positive on top or bottom.pretty sure closer to bottom. but it has a full tank of gas in it and its just sittin there is killing me. if yal could give me some pointers or smtn it would be great. or if yal have had this happen. id really rather work on it myself. 2 strokes are pretty simple but like i said i've never been in the bottom end of a banshee. but thanks for any help im readdy to ride. ps. it sounds pretty damn serious. to be honest with yal. Edited December 4, 2008 by POORBOY350 Quote
FASTOYS Posted December 4, 2008 Report Posted December 4, 2008 A dry screeching noise is definetly NOT a good thing. Might want to pull your clutch cover off, pull the spark plugs out, and turn the motor over with a ratchet on the crankshaft nut. Start pulling the clutch basket off and see whether the noise is coming from the clutch or crank area. Your welcome to call me if you need help. Quote
POORBOY350 Posted December 4, 2008 Author Report Posted December 4, 2008 A dry screeching noise is definetly NOT a good thing. Might want to pull your clutch cover off, pull the spark plugs out, and turn the motor over with a ratchet on the crankshaft nut. Start pulling the clutch basket off and see whether the noise is coming from the clutch or crank area. Your welcome to call me if you need help. thanks alot man. i took the cover back off and just checked it out and i turned it over slow and it was coming from the front bottom just about exactly where the crank is. but i guess ill put her in the shop so it'll be fixed right and i aint gotta worry about goin in there after smtn i dont know what it is ya know. but thanks for the help man. it almost sounded like the piston rings were just too big for the cylinders or somehting idk but ill let ya know if i need some help thanks man. Quote
POORBOY350 Posted December 4, 2008 Author Report Posted December 4, 2008 thanks for reading all that to lol that was alot of stuff but its hard to explain Quote
Hilarious Posted December 4, 2008 Report Posted December 4, 2008 thanks alot man. i took the cover back off and just checked it out and i turned it over slow and it was coming from the front bottom just about exactly where the crank is. but i guess ill put her in the shop so it'll be fixed right and i aint gotta worry about goin in there after smtn i dont know what it is ya know. but thanks for the help man. it almost sounded like the piston rings were just too big for the cylinders or somehting idk but ill let ya know if i need some help thanks man. did you drop something in the case while you were working on your clutch? why dont you pull the clutch cover off and give it a good look over? its not hard to do. Quote
POORBOY350 Posted December 5, 2008 Author Report Posted December 5, 2008 did you drop something in the case while you were working on your clutch?why dont you pull the clutch cover off and give it a good look over? its not hard to do. my man hillarious always helpin somebody in need lol. na i have took it off and put on about 4 times,im pretty sure i didnt drop anything, it was pretty easy once i figured out how to do it. i re adjusted it the other day took like 30 mins but wat gets me is how it just all of a sudden starts doing this when i was pretty sure i put everything back together right...? i think its shop time. this sucks!!! :: :shoothead: Quote
