nayr742003 Posted December 2, 2008 Report Posted December 2, 2008 I'm having a promblem with a carb issue i dont excatly know what it is called but here goes on my carb there is a pin keeps popping out on me and it makes the slide spin on me every few rides and the engine revs real high. I keep having to push it in lightly and then its all good is there a way to fix this and what the hell is the term for it? I half to use a long screw driver to pop it back in 1 can i drill that and put a screw in there? 2 Is it old and wore out and i just need new carbs they are stock carbs Quote
dragbanshee Posted December 2, 2008 Report Posted December 2, 2008 I'm having a promblem with a carb issue i dont excatly know what it is called but here goes on my carb there is a pin keeps popping out on me and it makes the slide spin on me every few rides and the engine revs real high. I keep having to push it in lightly and then its all good is there a way to fix this and what the hell is the term for it? I half to use a long screw driver to pop it back in 1 can i drill that and put a screw in there? 2 Is it old and wore out and i just need new carbs they are stock carbs Sounds like stock carbs, I'v never heard of that happening and I can't remember exactly how those look, surely a way to fix. Quote
notsed Posted December 3, 2008 Report Posted December 3, 2008 make sure its pushed in all the way and put some jb weld over it, that worked for me. make sure the slot on the pin is verticle to your slide before you jb weld it Quote
AKheathen Posted December 3, 2008 Report Posted December 3, 2008 make sure its pushed in all the way and put some jb weld over it, that worked for me. make sure the slot on the pin is verticle to your slide before you jb weld it ditto. /\ make sure it's completely clean and dry before you glue it. Quote
nayr742003 Posted December 3, 2008 Author Report Posted December 3, 2008 yeah i think that would work but that has to be something else that works with out jerry riggin it up like that im thinking of tapping it and useing a small screw. There has to be a way just havent found it or heard it yet. Quote
AKheathen Posted December 3, 2008 Report Posted December 3, 2008 yeah i think that would work but that has to be something else that works with out jerry riggin it up like that im thinking of tapping it and useing a small screw. There has to be a way just havent found it or heard it yet. jb weld is actually the best repair, like welding. simply pull the pin out, clean the hole out wth brake kleen and scratch it with a pick. remove any protrusions, and fill the hole. put the pin back in, and wipe of any excess flush with the bore. let it set, and it's like brand new. jb weld is metal replacement that can be ground and machined. done right, it will be 100 times better than a screw, and you wouldn't have to risk messin up the slide bore when you trim and shape the screw, which would be a piain in and of itself. i know it sounds like super glue, or duct tape repair, bu it's not. Quote
