I have +2+1 arms and Im unclear on what offset rims I want to get..Whats the diff between 4/1 and 3/2. I did a search so don't harass me you harassing fuckers.. :cool:
4/1 is 4inch on the inside 1 inch on the outside. 3/2 is 3 inches on the inside 2 inches on the outside.
So 4/1 will make it wider than 3/2...Is the stock wheels like 3/2
If you turn them inside out. Stock is 3/2. Imagine looking down on top of the wheel and seeing were the wheel center is in relation to the center of the wheel. If you have a 5 inch wheel center would be 2.5 inches. 3/2 makes it 2 inches on the outside of the rim(the side you see) 3 inches on the inside of the rim(the side you dont see) 4/1 moves the center futher to the outside so you have 1 inch on the outside and 4 inches to the inside. So a 3/2 would be wider then an 4/1 unless you flip the 4/1 around
