Running Engine $1000.00
Rubber intake boots/Boost $25.00
Reeds and cages $25.00
Carbs and cable $90 - 100.00
Airbox (or air filter) $50.00
Kickstarter $50.00
Gas Tank $25.00
Stock Pipes $20.00
Frame components
J-arm Frame $100.00 (title add $100)
A-arm - $250
Steering stem $25.00
A-arms / J-arms $200 - 300.00
Swingarm $25.00
Axle $90.00
Bearing carrier $40.00
Footpegs $10.00
Nerf Bars / Heel guards $40.00
Rear Hubs $40.00
Rear Sprocket & Hub $15.00
Rear Brake disc & Hub $15.00
Dogbone $10.00
Rear Grab Bar $15.00
Front Bumper Pushbar $15.00
Shifter $10.00
Skid Plate $20
Plastic
Front & rear Fenders $100 - $200.00
Radiator Plastic $35.00
Gas Tank Plastic $35.00
Seat w/ latch $20.00 - $60.00
Fender brackets $15.00
Electrical
CDI Box $40.00 - $50.00
Wiring harness / Loom $30.00
Coil $20.00
Headlights $30.00 - $60.00
on/off switch $10.00
Key w/ plastic housing $30.00
Taillight $20.00
Misc
Rear brake setup $90.00
Bolt set $25.00
Rear Shock $50.00 - $75.00
Front shocks $60.00 - 80.00
Front tires & rims $100.00 varies
Rear tires and rims $100.00 varies
Handlebars & grips $10.00
Clutch lever / perch $10.00
Thumb Throttle assembly $25.00
Radiator & Reservoir $30.00
Front brake lines only $10.00
Front brake lever/rezzy $20.00
Motor Mounts (set of 4) $10.00
motor parts:
cylinders $300
crank $160
shift drum, rods, forks $30
gears/tranny $120
cases $150 -$200
clutch cover $35
stator cover $ 10
stator + timing plate $70
internal bolt kit $20
head $30
flywheel $70
I can ship anywhere
