pdbanshee Posted November 19, 2008 Report Posted November 19, 2008 REBUILDING DO TO A BROKE ROD TORN HALVES APART AND REPLACED CRANK WHEN PUTTING BACK TOGEITHER THE CLUTCH PUSH ROD WOULDNT GO ALL THE WAY DOWN DOES IT REST RIGHT ON THE TOP HALF OR DOES IT STICK UP SOME ITS ABOUT 2IN STICKING UP HOW CAN I FIX THIS WITHOUT TEARING IT APART AGAIN THANKS FOR ANY HELP Quote
FASTOYS Posted November 19, 2008 Report Posted November 19, 2008 When fully seated the arm/lever sits about 3/4" above the case. Did you forget and maybe put the rod in before the lever?? Call me if you need any help and i will gladly walk you through it. Quote
pdbanshee Posted November 26, 2008 Author Report Posted November 26, 2008 When fully seated the arm/lever sits about 3/4" above the case. Did you forget and maybe put the rod in before the lever?? Call me if you need any help and i will gladly walk you through it. you were right had the rod still out fixed it now and almost done with the whole thing cant wait to get it back out in the dirt thanks for the help Quote
