  • 1 month later...
Located in Northern Macomb, 48042
Engine1,000.00
Intake boots/Boost25.00
Reeds and cages25.00
Carbs and cable110.00
Airbox (or air filter)40-70.00
Kicker50.00
Gas tank$30.00
Pipes oem25.00
Frame components
Frame300.00
Steering stem25.00
A-arms / J-arms300.00
Swingarm30.00
Axle100.00
Bearing carrier50.00
Footpegs10.00
Nerf Bars / Heel guards40.00
Rear Hubs45.00
Rear Sprocket & Hub25.00
Rear Rotor disc & Hub25.00
Dogbone10.00
Rear Grab Bar15.00
Front Bumper Pushbar20.00
Shifter10.00
Skid Plate20.00
Plastic
Front & rear Fenders200.00
Grill + Radiator Plastic30.00
Gas Tank Wrap Plastic30.00
Seat w/ latch50.00
Fender brackets10.00
Electrical
CDI Box50.00
Wiring harness / Loom35.00
Coil20.00
Headlights60.00
on/off switch25.00
Key w/ plastic housing35.00
Taillight25.00
Misc
Rear brake setup100.00
Bolt set25.00
Rear Shock80.00
Front shocks80.00
Front tires & rims100.00
Rear tires and rims120.00
Handlebars & grips10.00
Clutch lever / perch10.00
Thumb Throttle lever30.00
Radiator & Reservoir30.00
Front brake lines10.00
Front brake lever/rezzy25.00
Motor Mounts20.00
cylinders 300
crank 150
shift drum 10
gears/tranny 150
cases 200
clutch cover 30
stator cover 15
stator + plate 75
bolts 20
head 25
flywheel 75
