Rebuilding my quad, I lost one of the copper washers on the side drain plug for the antifreeze. Can I put it together without it for now? will it seep or what? Help, I'm standing here almost ready to fire it up.
thanks in advance
thanks in advance
You don't NEED it but it helps seal better. It wont hurt to start it up without it.
Thanks, can I get that back on without draining all the antifreeze? I doubt it
All you really have to do it take it out real quick and plug it with your finger and put it back on..
Another way would be to run the gas tank dry, tip it on its side with that plug up. I think it would still spit out and ^^^^ method would be easier.
thanks in advance
ok, you may not need it, but it not only helps seal, but it compresses when the engine heats up, and if you put it on real tight, the threads will start to stretch when it heats up you should back the plug offand put a wrap of teflon tape on the threads and don't overtighten it, just snug :sick:
I just put silicone on them when I lose those. btw..how do parts always disappear even if you put all of them in a single box or bag, or whatever. I always lose shit like that, and never find it. I'm still missing 2 pipe springs I lost over a year ago during a rebuild. :whoops:
