OKCterror Posted November 14, 2008 Report Posted November 14, 2008 Got all my new mods in, billet impellar, stator plate at +4, vf3's, coolhead with 19cc, and pingle petcock. Started it up and it idles ok. But the left pipe gets hot and not the right. Runs rough while driving and can barely keep it alive when im moving. Advice. Running stock carbs with 310s, pods, and everything else below. Help me out guys Quote
THE GRIM RIPPER Posted November 14, 2008 Report Posted November 14, 2008 If your @ or a little above sea level 310's seem lean... but I think one of your carbs mains sounds like its clogged if the pipe is getting extremely hot. Pull the bowl off and check that out. Quote
OKCterror Posted November 14, 2008 Author Report Posted November 14, 2008 would that explain the rough running Quote
some87 Posted November 14, 2008 Report Posted November 14, 2008 well if one side is not running it will run rough. i did that with one of my spark plugs after i changed them out and i forgot to plug the wire in. it still ran but ran like crap Quote
AKheathen Posted November 14, 2008 Report Posted November 14, 2008 Got all my new mods in, billet impellar, stator plate at +4, vf3's, coolhead with 19cc, and pingle petcock. Started it up and it idles ok. But the left pipe gets hot and not the right. Runs rough while driving and can barely keep it alive when im moving. Advice. Running stock carbs with 310s, pods, and everything else below. Help me out guys what fuel are you running? chech your choke tube and pull the pods to check that the slides are mooving right. Quote
magz Posted November 14, 2008 Report Posted November 14, 2008 make sure there gas in both carbs also, maybe 1 carb isnt filling up the bowl with gas, drain a little out the bottom screw hole. Quote
1996dragshee Posted November 14, 2008 Report Posted November 14, 2008 pull your carbs and clean em..one grain of sand or dirt in the needle seat can clog your shit..have you always been running 310s? how do your plugs look? Quote
OKCterror Posted November 15, 2008 Author Report Posted November 15, 2008 they all look good, gonna pull the carbs and clean em Quote
MikeNick Posted November 15, 2008 Report Posted November 15, 2008 My bike was running horribly a few weeks ago and some friends figured out that I had a fouled plug. 1 pipe was hot 1 wasnt and it would run but when you got past 1/2 throttle it would cut out.. Quote
