glk45 Posted November 9, 2008 Report Posted November 9, 2008 i am wondering what is the smallest CC dome i can safely run on my bansh? right now i am running 21cc domes and i run on vp110 octane fuel. i would like to try out some 18 or 19 cc domes but i dont want to kill the bottom end of my motor. i dont have any motor work done.. one of my buds has 20cc domes and i need to out do him!!! thanx for any help Quote
gumby6t9 Posted November 9, 2008 Report Posted November 9, 2008 You need to do a compression test first then determine if you can go smaller on the domes. Quote
05.Banshee.SE Posted November 9, 2008 Report Posted November 9, 2008 160+ Compression you need race fuel. Quote
Ryanman05 Posted November 10, 2008 Report Posted November 10, 2008 There is aways someone FASTER Quote
Wildcardracing Posted November 10, 2008 Report Posted November 10, 2008 Do a compression test so we know where you are with the 21's. I can tell you that you are losing hp with the 110 if you are under @170 psi static compression. 21's at sea level should only require 100 octane even with a +4 timing advance. I don't recommend running high compression above 160 untill you true/weld your crank. By the way welcome to the HQ Quote
