Skittle Posted November 5, 2008 Report Posted November 5, 2008 Just picked up a 96' Banshee with some mild work done. Guy explained that it has a 22cc wiseco domed piston. I wanna make sure the bike can run on pump gas fine,as he said it's currently running on a 100 octane mix but he said pump will be ok. Sorry for the noob question,thanks fellas. Quote
Dick Wheels Posted November 5, 2008 Report Posted November 5, 2008 You could pee in the tank and it would run with those domes! lol J/K. You should be fine even with 93 pump on that Quote
dajogejr Posted November 5, 2008 Report Posted November 5, 2008 there is one true, fool proof way to tell if a bike needs higher octane or not...compression ratio. However, if you're running 22cc domes, more than likely premium pump gas will work just fine. Quote
Skittle Posted November 5, 2008 Author Report Posted November 5, 2008 I'll probally skip the peeing in the tank part,unless the bike gets under my skin. lol Thanks to both of you. :-D Quote
jayzx10r Posted November 9, 2008 Report Posted November 9, 2008 (edited) Welcome to the HQ!! You gotta give it a compression test. I think the baseline for premium pump to a 50/50 mix with race fuel is about 155lbs. I have 165lbs and I mix 50/50 with 100LL AVGAS. Edited November 9, 2008 by jayzx750 Quote
