A while back my shee started acting up, it was making a horrible grinding/rubbing noise from the bottom end and when i put it up on a jackstand and shifted down it clunked and stuck in gear. I pulled the motor, split the cases and can't visibly see anything wrong. Is there any way of telling if the shift forks are bent slightly or if a bearing in the gear packs is bad.
Any advice would be great
