#1banshee Posted October 29, 2008 Report Posted October 29, 2008 What do you guys have? I want to switch carbs 2into1 setup.. let me know what you guys have.. Quote
RadarRacing Posted October 29, 2008 Report Posted October 29, 2008 They usually use a 35mm or 39mm keihin PWK. I have a set of carbs 35.5 keihins i'd separate if you had another buyer for the other one or buy both for $250 and you could sell the other or convert it to alcohol and keep it. Then you'd get the carb you need plus the richer cel needle and jets. Quote
#1banshee Posted October 29, 2008 Author Report Posted October 29, 2008 They usually use a 35mm or 39mm keihin PWK. I have a set of carbs 35.5 keihins i'd separate if you had another buyer for the other one or buy both for $250 and you could sell the other or convert it to alcohol and keep it. Then you'd get the carb you need plus the richer cel needle and jets. I will let you know on that im waiting for someone to get back to me on a carb... I will PM you if needed and I will buy both. Quote
