Tyfro! Posted October 28, 2008 Report Share Posted October 28, 2008 hellpppp!!!! is my bike about to blow?????? Quote Link to comment Share on other sites More sharing options...
351ranger Posted October 28, 2008 Report Share Posted October 28, 2008 need more info. where does it sound like its comin from? left side-right side? is it always there or does it depend on gear-speed-temp? Quote Link to comment Share on other sites More sharing options...
Tyfro! Posted October 28, 2008 Author Report Share Posted October 28, 2008 left side, very loud, louder than the idle,always does it........ Quote Link to comment Share on other sites More sharing options...
THE GRIM RIPPER Posted October 28, 2008 Report Share Posted October 28, 2008 Quote Link to comment Share on other sites More sharing options...
Tyfro! Posted October 28, 2008 Author Report Share Posted October 28, 2008 all i needed to know, i'll tear off the top end once i'm done watching my movie...... Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted October 28, 2008 Report Share Posted October 28, 2008 Whoa here. Thats not all you needed to know. Did it just start doing it? Is this a fresh rebuild and then you heard the noise? What if the noise is a loose stator or loose flywheel rivets? What if its a transmission noise? Start with isolating the noise, then go from there. Why not do a compression test or squish test before tearing apart the top end? Quote Link to comment Share on other sites More sharing options...
Screaming Yellow Zonker Posted October 28, 2008 Report Share Posted October 28, 2008 I would start off by pulling off the stator cover and put a socket on the flywheel bolt and rotate the engine forward and backward with the spark plugs removed. *side note** check the spark plugs for any type of metal shavings or gray matter on the plugs* this might help narrow down the area of the noise... Quote Link to comment Share on other sites More sharing options...
Tyfro! Posted October 28, 2008 Author Report Share Posted October 28, 2008 piston was slapping on the left cylinder, the tops of the pistons where PURE BLACK, like no silver at all just BLACK, and my domes where all black too i will get pics in the morning... Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted October 28, 2008 Report Share Posted October 28, 2008 Pure black is normal. Its the carbon deposits from your fuel. How do you know the piston was slapping? Quote Link to comment Share on other sites More sharing options...
Tyfro! Posted October 28, 2008 Author Report Share Posted October 28, 2008 i can tell because the cylinder is scratched up pretty good, and the rings are like gone, like they where being disinigrated...... Quote Link to comment Share on other sites More sharing options...
