I've found a local shop that will make my stainless steel brake lines with fittings, new banjo bolts, and washers for $75. I need to know the lenght of the front brake lines with stock arms or +2+1. I will be running 2 lines off the master cylinder. I also need to know what is the length on a brake line for a +4 swingarm with round style carrier. I am at work, so I can't measure. I did have a 28 inch rear line that was way too long. I should have measured then but I didn't. Thanks!
  • 2 weeks later...
I figured this might help someone out. The rear brake line length with a + 4 swingarm with round housing style carrier is 23 inches from banjo to banjo. The front brake line length when running +2+1 a-arms and 2 lines directly off the master cylinder are 54 inches banjo to banjo. Hope this helps someone.
Edited by grpark20
  • Like 1
