Does anyone have a 73mm cheetah PV cyl on the bench that could measure the sleeve outside diameter? The part that extends down into the engine case...the cyl skirt/sleeve that sticks down. Could you measure the diameter across the outside using a vernier. Im wondering if they will fit my cases that are setup for a 72mm cub cyl..... Anyone know how much clearence there should be from the sleeve to the cases?? Im wondering if they expand much thats why the factory has a lot of slop....like 2mm
Thanks for any input......
