You could quite possibly have some trash in one of your carbs. This just happened to me yesterday. Take the carbs off the bike, and remove the bowls. I don't know what your level of mechanical abilities are, but don't let carbs intimidate you. Take both jets out and make sure you can see though them. If not, I use a torch tip cleaner to get the junk out. You might also go ahead and adjust the float height while you're in there. Clean the whole inside with some carb cleaner, and reassemble. Be super careful not to get any trash or grit in the carb. It should take you no more than about 30 minutes to have them off and back on. Try that, and see if it works.
