f4istunna Posted October 19, 2008 Report Posted October 19, 2008 Have a set of toomey's w/ silencers $200 shipped in the 48 states. Pipes have some rust near cylinders but look pretty good when mounted w/ plastics on. Silencers in very nice shape. Click the thumbnail for bigger pics Going to try and start getting into more real estate investments around spring early summer so like to free up as much cash as i can beforehand I have quite a bit more i have to list up when i have time to go through it all. Selling/parting both of my parts banshee's, my yfz and one of the 250r's. Nice having a garage full of bikes and parts but i got a little carried away lol. For now im gonna keep my shee, 1 of the R's and my raptor (still owe more than its worth or it would go too. Have quite a few sets of wheels and tires, 2001 banshee frame w/ title, 97 frame w/ bill of sale, cylinders, cases, stock pipes. Ill make a complete list sometime this week once i go through everything. Quote
LiftdT4R Posted October 19, 2008 Report Posted October 19, 2008 Good deal on the Toomeys!!! Where are you located? Any pics of the 250R? Quote
f4istunna Posted October 19, 2008 Author Report Posted October 19, 2008 (edited) I always forget the location lol Ne ohio near pa line (inbetween cleveland and pittsburgh). Yep heres the R It needs either reeds or carb rebuilt, Wouldnt start one day so i i started swapping parts from my other R, tried a few electrical nothing. Threw the carb and reeds in and fired right up. Rear shock needs serviced and rear brake pads. Has full fmf, protaper fatbars, dg bumper, ac nerfs, kn filter otherwise pretty much stock. Motor has around 160psi. Good frame. Plastics are stitched in a cpl spots its a 86 Gotta get $1500 firm if i sell it which i know im gonna regret later lol Edited October 19, 2008 by f4istunna Quote
f4istunna Posted October 20, 2008 Author Report Posted October 20, 2008 Toomeys Sold and shipped thanks bob Working on making a list of the rest, i found another banshee box buried in the corner too. Quote
f4istunna Posted October 21, 2008 Author Report Posted October 21, 2008 Went through alot of the parts today. Prices are + shipping unless posted shipped. Will deal if you buy a few things. I can accept paypal or money order whichever is easier for you. Have pics of some of it still have to get pics of some. All parts are in working useable condition unless stated, used w/ normal wear. All from 95 or newer quad. Most from the 97 or 01 . NE ohio near youngstown if close feel free to pick up. - Engine cases w/ side covers normal chain slap damage to left no leaks, cracks $95 - Oem swingarm could use paint or pc bearings seemed good $25 - Oem gas tank w/ petcock and cap $20 - Kicker lever good splines $20 shipped - Kick shaft w/ spring, gear, bushing Good splines $17 shipped - Trans main & counter w/ all gears, c clips, bearings, sprocket nut... $100 shipped - Complete clutch - basket, hub, plates, rod, springs etc. 1 spring bolt missing but i should have one for it, plates show wear but still good life left $50 shipped -oem steering stem w/ 7/8 barclamps, and mounting clamp/bushings $30 - Rear wheel hubs good splines $40 shipped - Front Brakes complete master/lever, lines, and calipers w/ 60-70% pads $65 shipped - oem Spindles w/ guards $30 shipped - Oem axle cosmetic wear, good splines and threads $30 - Rear brake m/c w/ lever, resivior and lines $35 shipped - Pipe hangers $17 shipped - Front fender brackets $17 shipped - Front hubs w/ rotors good shape, straight rotors, bearings feel good. $50 shipped - Radiator no leaks w/ overflow bottle and hoses $20 - wire harness cpl cut wires but ends still there to work w/ headlight switch housing switch is missing a peice inside but rest in good shape no cdi or coil $35 shipped - Shift mechanisms shift drum/forks, star, shift shaft and shifter lever etc $30 shipped - F & R sprockets w/ sprocket hub 41t and 13t good shape $20 shipped - Engine mounts $17 shipped - Seat needs recover (hole) and foam repair or replace good pan and latch $15 - Front shocks yellow springs need cpl bushings $20 - Rear shock linkages $17 shipped - Stock axle minor bend on right (only noticed down the road in high speed) $10 - Stator w/ adjutable timing plate (meter tested good) quad bought needing rebuild then torn down so never tested. Red wire cut and was inline crimped in place. end still intace could be soldered $55 shipped - Seat Gray cover nice shape w/ latch $40 - Cylinders 64mm stock porting untouched, left has some scoring nothing major. right had over 100psi left around 60psi should be bored but a hone might do. Pistons come with $175 - Full chassis skid w/ all bolts and clamps $50 - Ac grab bar one taillight tab has jbweld, not cracked all the way through just the tailight bracket the rest is in good shape $15 -Ac front bumper polished bottom pushed in a little from nosedive mounts up good and hard to tell on quad. $15 - Mikuni Stock carbs w/ tors and cables $60 shipped - White front shocks w/ bushings $20 - Pro Armor Nerfs polished w/ black nets (nets fit but extra peices towards frame taped up) straight $50 - Spindles $30 shipped - Clutch lever/perch w/ cable and ebrake cable $20 shipped - Front hubs w/ Rotors straight no grooves need bearings $45 shipped - Stock pipes and silencers sanded and painted high temp black $50 - Stock metal footwells $10 - A arms silver straight, normal paint wear on lowers good balljoints and boots come w/ tie rods $90 - Radiator w/ overflow $20 - Wire harness no components good shape $25 shipped - Rear Brake Caliper w/ mc lever, brake line and resi, good pads if mem serves $60 shipped - Stock airbox w/ lid and foam filter $30 - Headlight/run switch $25 shipped - Stock head very minor buildup on one dome other one mint $25 shipped - Thumb throttle $25 shipped - Tie rods w/ good ends and boots $15 - Stock footpegs worn but still grab $20 shipped - Oem rear wheels straight normal wear on lips $45 - Oem front wheels straight w/ wear on lips $45 ($80 for all 4) - Like new kenda front tires 22/7/10 (short 22) $30 - Oem clutch perch/lever w/clutch cable $17 shipped - Carb caps w/ tors good wiring $15 shipped - ignition switch w/ key $25 shipped Few things you guys can have free if interested just pay shipping - stock airbox cut out (completely open) w/ uni filter - white rear shock spring stock - stock crank needing a rod bearing - pink front shocks ( 1 is bent) Have white full fender, and white race cut plastics, 01 frame w/ title 2 dents in front from bumper straight, 97 frame bill of sale. Local only on the frames and plastic sorry. also have quite a few sets of misc 7/8th handle bars $5 a peice have one peice design and crossbar type. If you'd like to see pics of anything just ask. Ill post up more when i get time also. Quote
f4istunna Posted October 21, 2008 Author Report Posted October 21, 2008 (edited) Also have some auctions going w/ about 3 days left if anyone is interested heres one of them just click other items http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=220296922861 All Parts Will be Shipped by Next Business day Edited October 21, 2008 by f4istunna Quote
