scroll24_7 Posted October 9, 2008 Report Posted October 9, 2008 So im getting water in my tranny oil and I know its not coming from the inside, its when i go trail riding and I hit some water. Where would water be getting in from???? Thnx. Quote
Misssppelllleddd Posted October 9, 2008 Report Posted October 9, 2008 Could be from anywhere. Check these things. Clutch cover gasket, bad dipstick o-ring, bad seal on the sprocket shaft, bad seal on the clutch pull arm, leak where the crankcase halves meet, or if worst comes to worst then the crankcase halves or clutch cover are cracked somewhere. Are you seeing an oil leak anywhere? Check the cooling system anyway. Might be a bad seal on the impeller or bad seal where the clutch cover and cooling tube meet. Quote
J-Madd Posted October 9, 2008 Report Posted October 9, 2008 Could be from anywhere. Check these things. Clutch cover gasket, bad dipstick o-ring, bad seal on the sprocket shaft, bad seal on the clutch pull arm, leak where the crankcase halves meet, or if worst comes to worst then the crankcase halves or clutch cover are cracked somewhere. Are you seeing an oil leak anywhere? Check the cooling system anyway. Might be a bad seal on the impeller or bad seal where the clutch cover and cooling tube meet. Quote
scroll24_7 Posted October 9, 2008 Author Report Posted October 9, 2008 It cant be an impeller seal because I can ride it all day long and not get water in the oil as long as I dont try to cross some water, when I get across the water it will get grey/white. Quote
