BanditOnTheBanshee Posted October 5, 2008 Report Share Posted October 5, 2008 i just put my banshee on a new frame, while i had it apart i took off the clutch cover so i could polish it, and the head so i could put on the bolts that came with a bolt kit i bought on ebay, after i got everything back together i started it, and now its leaking antifreeze from between the jugs and the case, i thought it might have just be the gasket, so i replaced it. This however didnt at all solve the problem, anyone have any idea why it would be leaking from there, or how to fix it? Quote Link to comment Share on other sites More sharing options...
Indubitably Posted October 5, 2008 Report Share Posted October 5, 2008 i just put my banshee on a new frame, while i had it apart i took off the clutch cover so i could polish it, and the head so i could put on the bolts that came with a bolt kit i bought on ebay, after i got everything back together i started it, and now its leaking antifreeze from between the jugs and the case, i thought it might have just be the gasket, so i replaced it. This however didnt at all solve the problem, anyone have any idea why it would be leaking from there, or how to fix it? Your base gasket doesn't come into contact with the coolant. If coolant is pooling on top of the case check the head gasket first. If that isn't the problem check the o-ring on the tube that comes out of the clutch cover and goes to the head. Quote Link to comment Share on other sites More sharing options...
glamis0812 Posted October 5, 2008 Report Share Posted October 5, 2008 Sounds like the oring on the tube. Quote Link to comment Share on other sites More sharing options...
BanditOnTheBanshee Posted October 5, 2008 Author Report Share Posted October 5, 2008 ok im sorry guys the antifreeze was coming from the bolt that drains it on the side of the cylinder..dumb more broke me...thanks glamis Quote Link to comment Share on other sites More sharing options...
