MikeNick Posted September 16, 2008 Report Share Posted September 16, 2008 SO I put a new clutch in aswell as a inner hub, new shift shaft an easy shift spring from Jeff and new pressure plate and a Cascade Adjuster. I rode it around my house an down the road an felt a hot spray hitting my leg. Pulled it back in the barn an all my tranny oil was leakin out. Well I took it all apart today cause I thought the gasket was messed up and I also need to readjust the clutch and all the bolts holdin the damn cover on were loose!!! I snugged them but didnt use a torque wrench because I'm afraid of stripping one out. So do any of you guys put Medium strength Locktite on the bolts when ya put it back together.. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted September 16, 2008 Report Share Posted September 16, 2008 I put blue or purple loctite on EVERY bolt on a banshee. They are vibrating bolt loosening machines. I use blue on the larger stuff and purple on the smaller stuff works great. The other problem i have had is when installing the stainless allen bolts for the clutch covers. maker sure you run a tap into the cases and make sure the bolts are going in all the way. I have had it happen where the bolts feel tight but are not tightening down on the cover because they are a little too long. you may need to take a little of the length. Quote Link to comment Share on other sites More sharing options...
MikeNick Posted September 16, 2008 Author Report Share Posted September 16, 2008 I put blue or purple loctite on EVERY bolt on a banshee. They are vibrating bolt loosening machines. I use blue on the larger stuff and purple on the smaller stuff works great. The other problem i have had is when installing the stainless allen bolts for the clutch covers. maker sure you run a tap into the cases and make sure the bolts are going in all the way. I have had it happen where the bolts feel tight but are not tightening down on the cover because they are a little too long. you may need to take a little of the length. THanks for the reply man...Much appreciated.. Quote Link to comment Share on other sites More sharing options...
