In the past some guys asked me how did I hooked the exhausts on to the RZ, this is real easy, but to the guys that need the info here they are...
I took the old flange from the RZ exhaust, or you can let someone laser cut it for you. I just made a adapter on a lathe which is the outside diameter of the banshee male exhaust connection which is fixed to the cylinder, the diameter is 45mm, my inside diameter is 38mm which is good for a ported 4mm. I guess the picture will give all an idea. You don't need to make it my way, but here is the pics..
looks good. i made a couple sets similar to them before. When I made mine i took the ID of the pipe just past the flange. I also made the cylinder the same diameter so there was no disruption in flow.
My exhaust port diameter is 38 on my 4mil, so thats why the flange is 38 as well...
