onebadbanshee91
Everything posted by onebadbanshee91
  1. haha already have the tors eliminator and have removed all the tors wires from the harness long ago. thanks for the reply
  2. Iv'e had problems with starting my banshee and keeping it running. I had this problem and then it seemed that it had gone away. Took it out riding road for about 2 hours through trails and out in the pit. I had shut it off and it would not refire. Finally got it running took it around the pit and it just died. It has not ran or had spark since. Its getting fuel and air and the plugs arent fouled. If I have no spark where do I start looking? Is the anyway that I can test to see if its perhaps my coil or the stator? thanks please reply asap .....I wanna try and get some riding time havent been out in a while lol
  3. A friend had her warrior out and it just died, lights went out and the starter was not even cranking. Pulled the fuse before the starter relay(thought it was solenoid) and it was blown. We put another 10A fuse in but the end broke off so we put a I believe 32A fuse in and I was able to turn the lights on. When you push the start button the starter relay makes a vibrating tick noise. So we pushed the quad and you can jump start it and it runs fine. So is the starter relay bad or what? Let me know soon because she ready to take it to the dealer and Id like to save her some money.
  4. TORS is eliminated and the coil has no power going to it and the orange wire going from the coil to the cdi box is good.
  5. My dads banshee has no spark we tested it two way. holding the plug to a head bolt and kicking it and using a test light in the orange coil wire. We have switched the whole stator assembely from one of our other banshees and still soesnt work and we have also changed the cdi boxess ,but stiil have no spark. I thought it could be the key or the killswitch. Im running out of ideas.
  6. My banshee has a stock head on it now ,but the previous owner told me it was shaved....I think he was BSing. Im running 100 octane fuel mixed with Maxima Castor 927 and Im riding at sea level. I want to install a coolhead (undecided which one) and wanted to run 20cc domes. Im not sure if the cranks ever been welded or if its stock. If it wasn't welded will the carnk hold? What dome size do you reccomend? If you guys need to know anything else or if you have any suggestions let me know. Thanks!
  7. We really need a FAQ (frequently asked questions) section for the newbies. The same questions keep being repeated. I just think it would help alot.
  8. I noticed a few new forums were added and I really think we need a FAQ section.
