100hp-shooter
Everything posted by 100hp-shooter
  1. Brooke come on this is great dont ban either of them .... ive never laughed this hard in my life ... omfg this is funny as shit ..... come on now brooke back away from the "ANYKEY" on the laptop and go have some Java.....this post is freaking funny as hell.... This is Roostin room right .... should be able to speak your mind and voice your opionions in here as long as its not direct at shop banshee or shop owners..... Flame away this is funny shit guys..lmao Shooter out !!!
  2. lmao ... it pays to be a robot programmer ... that and owning a shop and getting everything at cost helps. lol
  3. I have two and in the process of building up a third for Pro ATV class. 2002 LoneStar XUWL +7 Stretch drag setup with a 350 VNT Turbo Motor 1999 Chopped and lighted 398 7mm stroker motor setup. 350hp Price Snowmobile motor with a 250hp two stage nitrous shot in a solid geometry chassis.
  4. with a 22 inch carlise and 19 / 41 gearing and 2:68 Ratio Straight cut gears i tripped the dyno off at 128mph at 10,200 RPM..my motor makes it max hp at 11,700 ...now thats fast... track times... 6.79sec at 101.58 in the 1/8 11.12 at 109 in the 1/4 .. burned it up 100 ft after 1/8 and still made this time... Never made a full 1/4 mile pass yet ..maybee this year.... With the chassis and added HP i shoud be hitting low 6.3's in the 1/8 possible a high 6.2. Shooter out
  5. Im re-working a new cylinder setup here in the shop for my machine later next week. Ill be putting a stock cylinder big bore with triples and crazy port timing to it. Its way outside the norm of running on a motor with CPI's but from what we have seen in the shop on the Dyno with these new pipes this cylinder setup on my 7mm should blow over 110hp. Well keep you all informed of the outcome. Were shooting for at least a minimum of 100hp on gas and 110hp + on Meth. Then maybee well throw some nitro at it to see if we can get it to the 120 mark. Wish you all the best of luck on your strokers and keep an eye on your rod play, crank bearings and air seals...all of these will either kill your motor or rob power. Later, Shooter
  6. ummmm im making over 100hp and ive got a +12 . ... dont know why but it sure does bling bling in sun... Seems to work well though...still wheelies sometimes but most of the time it just hovers the front tires about a foot off the ground. hope it helps
  7. this is bolt up for under a million dollars ... hahahaha I know louie is finished with his but what the cost will be i have no idea but i like the idea of a billet cylinder ... thats sweeeet.. Shooter
  8. Well guys and gals ...lets see who you think builds the best bolt up monoblock setup for the banshee ?
  9. Barracuda, Well i have a 7mm stroker right now. My machine is a 398.6 cc. The cylinder is a stock cylinder .020 over. / with the 7mm stroke its a 398.6 calculated. To do the case port do not mill the case out to the max's. Since a 4mm Stroker crank is a direct drop in .. the only difference between a 4mm and a 7mm is 3mm. So you only need to mill 1.5mm's from the bottom of the case and the top of the case to clear the rods on the crank. As for the carbs yes a 35 PWK is a good carb ... i run 35 PWK's on my machine but we bored mine out to 38mm. I would ask your motor builder about the new PWM's though .. they are the cat's ass. Now if you mean your building a 420 big bore with a 7mm stroke your going to have around a 480cc + or - a few cc's .. since a 420 with a 10mm is a 499cc. Get that thing dynoed when you done and lets see the results... id be interested on how it sets up against mine if you going full drag that is. Hope it helps Shooter
  10. whats a drag race ? hahahaha Whats 1/8 street drags... ? Come on guys ...its all in good fun .. im telling you all you have to come up to Mid Michigan Motor plex in Stanton on the 4th of October for the 1/8 mile street drags ... youll have an absolute blast.. stop over to our trailer and shoot the shit and grab a Gatorade ive always got lots. Id rather have beer but not while im riding ... EVER... I hope you can all make it up there .... its an absolute blast ... and the track is awesome for street drags.. Besides im shooting for the 6.5 sec. low 6.6 mark at 102 + mph.. It will funny just to see me shoot out of control if all else. hahhaha Later guys, Shooter Thanks for the Vote Nyuk i voted for you !!! : )
