Hi everyone, is there a way or formula to figure out the octane requirement of a given engine. Say you have X #of cc's, or bore, porting layout, pipe, and dome size, and yes deck height. Does the octane requirement change with port timing? Or is it the deck height. Can you figure compression ratio on a two stroke like you would on a four stroke; but start your cylinder volume at the place where the ports are closed and then add the dome volume. Or can you figure it out by the PSI reading you get from a compression gauge. Any answers would be greatly appreciated. Sorry one last thing, when domes are custom cut, are all you doing is changing the compression?
