Tharris24
About Tharris24
  • Birthday 10/26/1991
    Corpus Christi Tx
  • Interests
    Hunting, fishing
    Shocker yellow/white
Recent Profile Visitors
Tharris24's Achievements
  1. I went and put a couple runs in yesterday. I put 320 mains Instead of the 340’s. It sounded crispier at idle but it’s still doing the same thing. I put my hand on the right exhaust while cruising and there was flow but nothing like the left exhaust. I got a video of it. Wish I could post videos on here lol Sent from my iPhone using Tapatalk
  2. Update: -Carbs are synced -New dynatek coil -Noticed that the bowls were on the wrong carb. Swapped them -Installed choke equalization tube Starts up first or second kick. Idles fine. But still bogs under a load. Sent from my iPhone using Tapatalk
  3. Also, it passed the leak down test
  4. You may be on to something with the mis-adjustment. Because when it’s running you can’t put it back into neutral. Bring home an ohm meter from work so I can rule out the stator.
  5. It idles fine and it will respond to throttle in nuetral and it’s crispy. But when you put in gear it doesn’t have the power that it should. I tried posting a video. But the video is too large
  6. So I just got a freshly built 421 banshee. It starts up and high idles but once you put it in gear the idle goes back down to normal. Then when you go to get on it, it sounds like it’s sputtering and when you get all the way to 6th, it sounds like it’s turning off and on. New spark plugs. I synchronized the carbs today and i got the idle issue fixed but it’s still running horrible.
