With a floated ground stator and the addition of a Trail Tech rectifier, you should be able to use your stock light switch, wiring, and frame ground for your DC conversion. Ensure proper connections: connect the stator's AC outputs to the rectifier's AC inputs, then connect the rectifier's DC outputs to the bike's electrical system, with the negative DC output grounded to the frame. Test the setup to ensure proper voltage output and functionality of your lights and electrical components.
