Dragking99
Everything posted by Dragking99
  1. Nvm I got it figured out, but thanks for commenting
  2. I got it from eBay, it’s billet
  3. So my banshee is a 370 with stock bore Athena cylinders, 4 mill crank, Fmf fatty pipes, I’m trying to get my carbs in sync but it just ain’t working for me, the left carb air/fuel screw goes to where it’s needed but on my right carb I have to screw it all the way out for it to idle, then my right pipe is like popping (the bike rides awesome) it’s a fresh rebuild, new cylinders, pistons and all that, so I’m thinking about just buying new carbs, what size and brand would be best to go with and what should their jetting be? I really need help with this, thanks in advance, I believe the current carbs are khein
  4. So I just rebuilt my banshee top end, everything is new in top end, and bearings/seals are new in bottom end, problem is, my water pump gear keeps coming off, I’ve put it back on twice, water pump shaft does have a little play in and out, it’s an aftermarket billet water pump, I was thinking about adding some more washers so their wouldn’t be anymore play in it, what would you guys do, I really need help to solve this problem because I want to fix it and ride this weekend, thanks in advance
