Hi trying to get in the right ball park for my jetting on my 2000 banshee. I’m at 1496 ft altitude. jetted at 158 main and 50 pilot and clip on jh needle on last spot from bottom right now seems to be rich as 2 stroke oil comes out of both My exhausts zero leaks have done leaks down holds 6lbs for 24 hours. specs are
keihin 28 pwk’s
65.50 4mm stroker with 21cc stroker domes 795 wiseco pistons 140 compression both cylinders
some sort of port job has fmf etched into both cylinders on side and can see work done on inside very clean professionally done
fmf fatty exhaust system
tors delete
all oem electronics waiting on cdi from dynatek and will prob run curve 3 as I heard it’s closest to +4 timing
thank you for your time and help
