Okay so freshly rebuilt by me. 100% OEM motor. Pistons, rings, wrist pins, circlips, seals, and gaskets all new. Bike has T5 pipes and silencers. I mixed about 30-1 for first heat cycles to lubricate everything but usually mix 32-1. Bike idles perfect even in cold (35+ degrees). I have stock 26 mm carbs with tors delete and 280 main jets. No air box I have the 2 cones 1 on each carb. For some reason first has a slight bog if you gas too quick at any point in the gear but 2nd and 3rd if you gas at all it bogs down. I haven’t went past 3rd because of that. Bike only has an hour on it so. Any ideas on fix for problem? I order bigger jets was going to try 300.
