Hi,
I am about to finish my Banshee build, now I'm puzzled with the carbs.
I have EGT installed and I see the right cylinder running about 80°C cooler than the left one. Also in the lower RPMs it takes a little to get its act together, stuttering a bit.
At first and telling from the spark plugs I thought it was the fuel/air ratio, so I went leaner on the cooler cylinder, with little effect. Then I gradually tightened the throttle cable on the cooler cylinder, thus not changing the fuel/air ratio but increasing the cylinder load altogether. And, surprise, the stuttering went away and the temperatures equalized. In the end, I hat the slider in the right carb set about 1,5mm higher than the slider in the left one.
Then I readjusted the carb slides to equal height again (to make the problem reappear) and went looking for a reason. So I checked this:
swapped left/right exhaust pipes (tailpipes only, as they are custom built. elbows are stock) -> no change
swapped left/right carbs (choke removed/blocked) -> no change
swapped spark plugs and ignition coil leads -> no change
checked float levels (first with calipers, then with transparent tubing on the drain studs) -> equal
hosed down everything with brake cleaner -> no change in RPM, so probably no air leaks, including the L/H crank seal behind the stator
compression tested -> both cylinders equal
So now I am through with about anything that I could probably measure and check...
What on earth...? 🥶
Best regards
