Snapple80
Everything posted by Snapple80
  1. I pulled everything apart and the shift shaft claw was a tad out of adjustment and the eccentric screw was a little loose. Got it all adjusted and locked down but when I was putting the clutch basket back on I noticed slop/play in the basket and gear. Would a combination of all of that cause shifting problems? How much play is ok in the basket? Sent from my iPhone using Tapatalk
  2. First post, long time lurker. I'm having issues with shifting my banshee and looking for some advice and things to look for as I tear into mine. -It was locked up in 3rd gear and couldn't shift up or down. While changing from paddles to dirt tires to make it easier to roll around the garage I slammed the rear tires back and forth when I had it jacked up. When I put the bike down I checked and I had N and all 6 gears. The following day I decided to take it for a test ride down the road and it worked just fine but I only have N and 1-3 gears now. -I am going to start on the clutch side and see what I find before pulling the motor and cracking the cases. I know there are a multitude of issues it could be just looking for ideas on what to look for or any advice you all might have. Thanks, Snapple80
