imaduner
Everything posted by imaduner
  1. 300-310 main, stock pilot and I think I moved the clip down 1 position.
  2. We are running powerpros in frames w/super quiet silencers (92 db). 3 of us w/ identical shees are basically stock motors w/ K&N(no lid),carbon tech reeds,+4 timing, not the fastest guys out there but do well on the hills etc. The bottom end could be improved with more compression.
  3. Several of us have identical shees w/ powerpros pipes like baddest banshee described (ILR customer ??). They work fine...not quite as much bottom end as toomeys but way better on top. sounds like drag pipes if you have integrated silencers...doubt they are hush or super quiets tho.
  4. If you ride Oregon dunes the CPI's will NOT pass the noise req's !! I recomend toomeys w/hush or cascade silensers or I several of us run powerpros in frame's with their super quiet silencers and all are 90-91 db. These pipes rock !!! check em out www.thepowerpros.com they make pipes for most of the big guys and are available in many finishes as well as stainless !!! Good luck !!!! :idea:
