El Bori
Everything posted by El Bori
  1. Hi I know is been a while that you sold this set up. But you happen to remember how to install the trigger wheel in the crankshaft. I have one with this set up but have no instructions and this set works with no woodruff key so trying to figure out how to install the in the crankshaft and set the timing correct. I already try to call FTZ but they say is to old set up and they were no help. Thanks
  2. Help please I have a FTZ battery ignition system set up in my banshee was running good but I did a transmission rebuild and forgot to mark the trigger wheel in the crankshaft for the install position. This set up does not use a woodruff key to install the trigger wheel back in the crankshaft so I am not sure which position to install back on. I am pretty sure that has to have a correct position in the crankshaft do to timing so will tell the MSD box to fire correctly. I try to call FTZ for technical advice or instructions an no luck told me the set up was to old they have no clue.
