Justsayin6916
    Red and white,1996 CT racing pistons big bore ,billet cool head ,34 mm pwk power jet carbs,everything is billet fmf pro circuit pipes
Recent Profile Visitors
Justsayin6916's Achievements
  1. So if I have 19 cc domes I should put 20 or 21cc domes
  2. I have two different compression tester and I done the test each side like 8 times each with each one and cane up with the same from both and both are different brands and I think my elevation is 2000 ft above sea level I live in Las Vegas I have 19 cc domes what size would I need do I go up or down in sizes
  3. +10 what is that the advanced timing where it should be at
  4. Ok I don’t even know if it has an adjustable timing plate should it if it the stock one and what should my timing be at with an adjustable timing plate and if it’s to lean to I go up or down in my jetting to richin it and would it do that if it was to rich
  5. No it kick over with a little itty bitty kick doesn’t even need to be a full one bike fires every time cold or hot doesn’t matter
  6. Should I try and run a higher octane
  7. I run racing fuel and redline 2stroke oil is there any way to bring that down any withe like bigger dome or smaller domes I live in Las Vegas,nv and it seems like a plug lock would be stupid to do because it shouldn’t need a plug lock ever something is not right I just need to figure out what !
  8. I have 96 shee and it’s got big bore CT racing pistons in it with 19cc domes and billet coolheaded 34 mm carbs brand new fmf pro circuit pipes I have 210 psi compression out of each cylinder my spark plugs keep coming loose can someone please help me
