Stingray
    2
Stingray last won the day on April 9 2020
Stingray had the most liked content!
    1995 black 404 15 cc domes cool head drag port vforce4 reed spacers 8 deg advance shift mods owl 34 carbs CPI in frame drag pipes k&n filters dyna fsp Cdi
Recent Profile Visitors
Stingray's Achievements
  1. Im reading 10 marks on the ruler so one cm or 10 mm and when I blow up the pic I see over 2 mm from start of soot ring to the end. If I’m reading it correctly that plug would be slightly rich
  2. If the soot ring isn’t growing I would guess it is lean in the mid range color wise I like the 162 plugs any chance you can lift the needle 1 notch (lower the clip) with the 162 then do a 20 min ride no more than 1/2 throttle. Please post pick of 20 min plug whole then chopped only need to chop 1 plug for this test. Do you have a laser thermometer after your run take a temp of the cylinders and one of the pipe on each side about 3 inches off the jug. Thanks
  3. Is the place your doing the plug chop flat. The best info comes from a hard pull a hill climb is a good thing coasting is not.
  4. If so take off your filters and make sure the slides are going all the way up on both sides. The power jet kicks in at 98 to 100 percent throttle. Also make sure they are even at wide open throttle. Looking at your plugs ngk recommends color on top 3 threads. I only see color on 1 this would mean your plug is too cold of a heat range br7es would be better for your bike also the first 1/2 mm of the electrode should be shiny which means your engine is too retarded. If you plan on advancing the timing now is the time so you don't have to start over with jetting. There is no sign of transfer of aluminum at the base of the plug so I see no signs of ping or detonation. I would advance 3 to 4 deg.
  5. I use a digital caliper for measuring, harbor freight one will do. Until you main is correct make sure your needle is in the middle it is the last circuit you tune. My Procedure is to set idol Circuit first making sure that it is not too fat or too lean in the bottom and second I just the top end because the mid range is a combination of the idle circuit in the top and circuit Does your carburetor have a power jet on it on the top on the back? They usually have a hose going from the bowl to that jet.
  6. If it changed that much you need to do a leak down test those plugs are extremely lean they should have a 2 mm soot ring and yours are not even close. At least start it and spray starter fluid around all gaskets and intakes and listen for rpm change better safe than sorry
  7. Buy a leak down kit off eBay and do a leak down test before the tear down. Might have lost oil seal to trans
  8. Why dose everyone guess at jetting. Do a plug chop and you will know what you need to do. Warm bike up on old plugs till hot change plugs ride bike wide open like you are racing through all the gears clear to top safe rpm pull clutch and kill bike, keep clutch in till stopped do not idle cut threads off plug or slide a 3/4 hole saw over top of plug cut down till ceramic comes out easily measure soot ring with caliper 2 mm perfect smaller lean larger rich
  9. Yes it will have + and - 10 deg with 0 in the middle and the pointer is the split in the case
  10. Best power gains are 1 port job 2 compression 3 pipe 4 timing 5 carbs
  11. I run race fuel 40 to 1 with 927 castor 10 deg advance cool head with 15 cc domes and 68.5 mm big bore Pistons. I do plug chop after every mod and show no pinging (aluminum transfer at base of plug). If everything is sealed no leaks and jetted correctly you should be able to run 4 deg all day long. A plug chop will tell you everything you want to know about your timing and jetting.
  12. Don't forget the o ring on the pipe going to water pump
