McGrawz, thanks for the reply
Not yet... new plugs ....took apart and cleaned kill switch/headlight switch and all seemed fine. Stator resistivity tests fine on lighting circuit and ignition circuit.....ignition coil wires test fine....plug caps test fine...trimmed coil wires where they screw into the boots. I have two banshees and tried both coils...each of which tested around .4-.6 ohms. I know that is on the high side of the resistivity, but am hopeful it is close enough. From what ive read, coil failures are rare.
The kill switch wiring is integrated in the same plug as the headlights so i dont actually know how to bypass it completely... but as i said everything inside the switch looked good. Im going to check continuity all over the harness and see if i can find a short...or ground issue as you mentioned above.
If anybody has any other tips, I'm all ears
Thanks
