gary_garnett
Everything posted by gary_garnett
  1. Thanks guys another question is the PT pipes , are they chromed ? got some holes and was planing to get a patch welded to them cut out the hole and do an insertion patch or maybe looking for a High Rev Left pipe can’t believe they would corrode this bad picture looks worse than it is need to crop pic to big in file size 🙈
  2. Ok so the banshee i am working on that was was neglected for some time has multiple issues and i am working through them but as its the first banshee for me to work on . Usually work on jet skis motorbikes and boats. Got a couple of questions that i am sure you experienced guys could help me with. its not a stock Banshee and has PT PIPES Duncan International racing motor with PWK 35MM carbs and K&N filters. I have managed to get it to start bu doing the following. , cleaned out carbs (jets are 55 and 160 we are at sea level with high ambt temps ) ,all get were blocked up heavily with gunk and varnish. stuck fresh gas and new plush in after put a little oil down plug holes. 1 Got ho;es in the left exhaust pipe.(will get it welded up) 2Front brake master cylinder full of crud and sh1t. ( pulled the two front calipers of stripped them down cleaned and reassembled. flushed out brake line top to bottom and bottom to top. got a new master cylinder oem on order) 3 Front right shock found top insulator missing completely. are they standard oem on the WORKS SHOCK? and do they use NITROGEN/AIR? And at what pressure a they charged to ?(Works Performance Shock) 4 Radiator leaking so have found one on ebay made in Florida with life time warranty ( anybody had issues with aftermarket radiator) 5 throttle cable ,when converting from stock carbs to PWK is the throttle cable changed too.I am thinking of sticking a new throttle cable i i need to learn how to adjust the mixture screws at some stage. I made contact with DUNCAN racing who told me use 105 octane gas but at present running it on 98 as that's what we have at the gas station. I may still get two carb kits and redo the carbs again and stick the parts into ultrasonic bath as they were the worst carbs i have seeF thanks guys feel free to through the kitchen sink at me
  3. https://www.ebay.com/itm/Lifetime-Warranty-2Row-HD-Thick-Core-ATV-Radiator-For-87-07-Yamaha-Banshee-A012/253924238624?epid=2152111183&hash=item3b1f106520:g:nBwAAOSwl7NdSd~N seen this one with loads sold and life time warranty
  4. radiator has sprung a leak whats the best replacement. we don't race so don't need it bullet proof
  5. check link below on ebay https://www.ebay.com/itm/OEM-FRONT-SHOCKS-87-06-yamaha-banshee-yfz350-yfz-350-suspension-springs-stock/274013399548?hash=item3fcc78a9fc:g:TQ8AAOSwidpdgROZ
