Johnson87
Everything posted by Johnson87
  1. So no power coming out of stator just order oem new one
  2. Man am I glad I joined this site everyone has been more then helpful if I didn't join this I would of burned this thing or just kept buying useless parts
  3. Sorry that's a question I'm bad when it comes to electrical
  4. Ok so it will still spark with the kill switch unplugged to
  5. Just jump a wire across them will work right?
  6. My key switch doesn't work either
  7. Not there is that ok
  8. Where is the tors delete plug in because I don't see it
  9. What is the silver box on back of quad with single wire in it
  10. So getting fuel now but now I have no spark at all what's the most common thing to go bad on the spark issue
  11. Alright I'll let everyone know how I make out
  12. Well update did last down test leaking air around carb boot bolts not a huge leak but bubbles could that cause no start
  13. Thanks guys I'll go see if my local hardware store has these things if not I'll order a kit
  14. Stupid question how do you do a leak down test on this
  15. Tors delete yes brand new carbs
  16. When I dump fuel in cylinder heads and it fires it instantly revs out with me not touching anything
  17. Yea I'm at the point of smashing my head off my bench
  18. Fuel tap flows fuel it's a dual tap for two lines
  19. Reeds are good boots and gaskets are good
  20. Thanks guys I'll let you know tomorrow
  21. Yes just checked it
  22. Just rebuilt motor 120 compression and holds
  23. I was driving my quad went from 4th to 5th and cracked into the throttle out of no where it comes and died now it won't start unless I dump fuel into heads and when it fires it revs out really bad any ideas
