99sheee
Everything posted by 99sheee
  1. Cant say that i do.
  2. Im probably going to list them forsale shortly. Ive got 2 boxes i can let go with it actually. If youd be interested shoot me a pm and we may be able to make a deal
  3. Looking to trade my setup for a set of modified stock carbs or 35-39mm alky carbs with filters ect. Willing to add boot on my end. Pictures wont upload for some reason. Pm me for pictures. Chariot 2 to 1 adapter 38mm mikuni flat side carb Trinity stage 4 airbox adapter with filter.
  4. What kind of exhaust do you recommend? I can find out anything specific about the motor youd like to know. Its literally a stock chassis besides extended swinger. I plan to swap to a different chassis eventually. Just trying to get the motor running good now. Ill post a picture shortly
  5. Motor was built by previous owner which is a buddy of mine. Machine work was done by a local guy that works for a machine shop that has done all my porting and ect for years. Literally only thing this will be used for is drags. Whats my current carb setup worth? Flat side 38mm mikuni, with the chariot 2 to 1, and trinity air box. And if i were to go bigger carbs what size should i look at ect. Would like to run alky at some point.
  6. Ill look into that forsure. Like i said i really dont know much about these things. Im a washed up xc racer racer that has ran nothing but 4 stroke hondas trying to get into drag racing alittle with obviously a banshee. What kind of modded stock carbs would be a good setup? Im not opposed to swapping if it makes jetting easier and benefits.
  7. Just as tite states looking to trade 2 full sets of fmf exhaust for inframe or out of frame drag exhaust. One set of exhaust is fairly rough (few dents) but still work just fine. Will upload pictures later due to being at work. May also add cash for right exhaust. Closer to louisville ky the better. But can ship. Thanks!
  8. Didnt see where you recommended reeds or said you had some forsale? No need for negative comments. Just simply looking for parts.
  9. Its a drag bike. Im trying to make it work until i can afford a good set of duals.
  10. Thanks ill definitely look into it. Im having a hell of a time trying to jet that carb. A carb and different exhaust is definitely in the plan eventually. On a budget at the moment
  11. New to the whole 2 stroke world so dont know much about reeds. But looking for a set to go good with my setup. Anyone have anything? Build list below. Thanks! -4mill crank with welded 115 rod -66mm 795 series pistons (cylinders have been ported for the crank) - Boss cool head with 19cc stroker domes also been ported -chariot 2-1 carb setup with a 38mm mikuni carb. -fmf gold series
  12. Ive got a single 38mm mikuni carb with open air box. that i cant get jetted quite right. Its starts up fine idles fine and pulls fine until about 3/4 throttle to full throttle. Acts like its starving for fuel but pull the plugs and they say rich. Im currently running a 52 pilot and 410 main. Info to motor build is listed below. Any help would be greatly appreciated! 4 mill crank with welded 115 rod -66mm 795 series pistons (cylinders have been ported for the crank) - Boss cool head with 19cc stroker domes also been ported -chariot 2-1 carb setup with a 38mm mikuni carb. -fmf gold series full exhaust.
