Mmatti
    2000 Yamaha 350
Recent Profile Visitors
Mmatti's Achievements
  1. Okay perfect is non ethanol premium sold at gas stations? Or usually where you can find race gas? I've never bought it before
  2. So I Did a comp test today came out at 140 both cylinders were like the exact same haven't checked timing yet but both cylinders matched so that's a plus so I wonder if I'd be good to just run premium? Or is non ethanol premium better? It seems like i dont need to run race gas and premium like the previous owner said
  3. I dont know about the advanced timing the guy I got it from didnt say anything about that I usually mix 32:1
  4. Awesome thank you
  5. How would I do a proper compression test?
  6. I recently got a new banshee it has Toomey t5 pipes and silencer bored .20 over coolhead k an n pod filters no air box and force Reeds basically I'm just unsure of what kinda gas I should be running the guy I purchased it from said he would mix a can with 2 gallons ethanol free premium and 2 gallons race has with a 16oz bottle of redline oil just curious if that sounds like a good mix
  7. I recently got a 2000 banshee and when it's running it doesn't leak any gas but once I turn it off the gas will start leaking, then if I turn the petcock off it will still continue to leak but way way slower like a drop every couple minutes and I'm not sure if the petcock isn't sealing? Or what the problem is thanks for any help
