Blueshee98
Blueshee98's Achievements
  1. Okay I cut the coil wires back and reeds are good still sputtering so I’ll check the stator and go from there thanks
  2. Put a 27.5 in changed nothing
  3. Its kinda always sputter but it’s preety bad now and when the engines hot it’s almost impossible to ride. Stock needles and yes I’ve tried every clip position and wide open runs perfect
  4. Cmon guys I need it running good by this weekend
  5. I’ve cleaned the carbs multiple times blew air threw all jets plugs are brand new. The only mod I have is a set of t5s at about 5000 elevation 270 main and 25 pilot needle at the leanest position
  6. Hey so my banshee just started sputtering real bad in the mid range expecially when the engines hot tried moving the needles no help tried changing the main jet no help starting to think it’s something else anybody got ideas?
  7. Anybody got ideas?
  8. I have 280 mains in it now at 5000 elevation tried dropping them to 270 and 260 doesn’t change anything starting to think jetting isn’t the issue
  9. Hey guys just had quick question the mid range on my shee sputters pretty bad especially when hot the needle clip was on the 2nd to the top and I moved it to the first but still sputters a little what should I do?
  10. Stock carbs and the needle is in the leanest position but top end is perfect
  11. Hey guys just had quick question the mid range on my shee sputters pretty bad especially when hot the needle clip was on the 2nd to the top and I moved it to the first but still sputters a little what should I do?
