C63kay
C63kay's Achievements
  1. Cool also what spark plugs would you recommend I didn’t order yet I’m ordering once I know exactly everything to order hopefully by the end of the day
  2. All from fast racing
  3. Is there anything I should replace remove or add and also what size domes and what size jets should I start off at I run 93 and trail ride. What size swing arm and sprockets should I run I have Yfz suspension, fv4 reeds, cool head. Cylinders - Serval Wampus 421 Hot Rods 4mm Stroker Crank Keihin 35mm PWK Banshee Billet Water Pump Impeller Standard Flow WITH Gasket Oversized Radiator Modded Shift Star Clutch Pancake Bearing Gasket Kit Complete Seal Kit Engine Ice 1/2 Gallon Banshee Heavy Clutch Springs Spark Plug Chop Tool Cool Head Acorn Nuts Yamabond 4 Sealer Timing Plate - Billet Ignition Coil Spark Plug Cap KLG-type Sprocket Lock Washer Lock Washer - Folding - Clutch Nut Stock Rubber Intake Clamp
  4. Recently got my license taken away trying to get her fixed up blew her up on the last snow day ran on one cylinder for 2 seconds heard a loud bang and and it shut off cleaned out one plug and rode it home finally went to take it apart and one piston was missing g the skirt and the other was cracked. Crank is out of wack and I was looking to go for a upgrade was thinking about a 4mm crank the pistons ended up being Chinese .2 over I am looking to save as much as possible till I can start working again in a few months when I get my license I ride trails, I have yfz suspension, pro design cool head, stock cabs, v force 4 reeds, recently installed a chariot clutch basket and tusk plates. What exactly would you guys recommend.
